• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Navisworks
    Active Member
    dxf export fails
    489 Views, 9 Replies
    11-16-2009 11:50 PM
    Hi.
    When exporting a model of a process plant to dxf, all straight pipes are missing in the resulting dxf file. Has anyone experienced something similar?
    Dag Magne Ulvang
    CMR AS
    Norway
    Please use plain text.
    Employee
    Re: dxf export failes
    11-18-2009 02:15 AM in reply to: dmulvang
    Hi Dag,
    Do you mean DWF export? Navisworks doesn't have the ability to export to DXF as far as I know...
    Jeff
    Senior Software Engineer
    Navisworks
    Autodesk Ltd.
    dgorsman
    11-18-2009 07:32 AM in reply to: dmulvang
    When you say "... model of a process plant...", what program was used?
    Adopt. Adapt. Overcome. Or be overcome.
    Active Member
    11-29-2009 11:47 PM in reply to: dmulvang
    Yes, you are correct. I did mean dwf.
    Active Member
    11-29-2009 11:49 PM in reply to: dmulvang
    Originally the CAD model comes from a PDMS system, but I try to export to dwf from Autodesk Navis Works.
    Dag Magne
    Active Member
    11-30-2009 12:18 AM in reply to: dmulvang
    Hi again.
    When taking a second look, it seems that it is all cylinder representations are missing, which includes straight pipes and the middle of a tank.
    Dag Magne
    Active Member
    11-30-2009 01:45 AM in reply to: dmulvang
    Hi again. Today I found a suggestion in a similar thread "Missing objects (cylinders) from a DWF file" that I will try out; "disable parametric primitives", and see if this fixes my export issue.
    Dag Magne
    dgorsman
    11-30-2009 11:16 AM in reply to: dmulvang
    There may be object enabler issues at work here. There probably is an issue converting whatever PDMS is using for custom objects (as opposed to AutoCAD solids) into DWF format.
    Active Member
    12-01-2009 11:03 PM in reply to: dmulvang
    Hi.
    I have now tried a new export from Navis Works after disablling parametric primitives, but this did not help.
    Dag Magne
    Employee
    12-02-2009 12:45 AM in reply to: dmulvang
    Hi Dag,
    Could you attach the problem file (original from CAD application & NWD please if possible) along with reproduction steps or send it to Autodesk support as an issue please? I can make no promises as to when the issue will be addressed, but a reproduction case would greatly help speed investigation.
    Jeff
    Navisworks
    Autodesk Ltd.
