Thank you for bringing this issue to our attention.
There is no easy away to accomplish what you are trying to do so I suggest you to contact our developemtn tema directly:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
In Navisworks, you are able to hide elements in the view, export the view and the resulting DWF will have those items hidden but a DWF exported from Navisworks doesn’t have the sectioning in Revit.
The issue is that an element in the model will span across the section box and you can’t hide only a portion of a piece of geometry. As such you are selecting elements that are hidden by the section box using the select box.
We have some workarounds but they may not be what you are looking for.
Please try:
- Set the view orthographic, and set it to face the model from the front by selecting the view cube.
- Use the select box to drag a selection box around the areas that aren’t visible outside of the section box and hide those items.
(This would be best done by setting the view to an orthographic view mode, and setting the camera to face the front of the model to select the top bottom left right portions outside the section box to hide them, then rotate the camera to face the left of the model and selection the left and right portions).
Keep in mind that an element outside of the selection box may not be completely encompassed by the select box, and therefore wont’ be selected. You can hold down shift to select any element that has some geometry in the selection box; however, if you do this in the outside portions, the elements in the section box may run out into those portions outside the section box and get selected.
After you turn off the section box, you may want to hide the ones that were missed individually.
If you have around 50 elements to select the best way to ensure you only select what is in the section box, is through the normal selection tool, holding down CTRL while you select to multi-selection. This tool ignores elements hidden by the section tool.
Fernanda Lima Firman
Technical Support Specialist
Customer Service & Support
Revit Clinic
If this helped solve your issue - remember to 'accept as solution' to help others find answers.
