• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Navisworks
    Member
    mikeford12730
    Accepted Solution
    Viewport Export - Image size - Navisworks Manage 2012
    674 Views, 4 Replies
    11-01-2011 02:38 PM
    I have saved viewports in Manage 2012 and exported the viewports as a viewport report. I want to know if it's possible to increase the size of the viewports? Right now they are very small and blurry, when team members enalrge the images from the html reports.
    Any help would be greatly appreciated.
    Thanks in advance,
    Mike
    Please use plain text.
    Product Support
    Re: Viewport Export - Image size - Navisworks Manage 2012
    11-03-2011 05:40 AM in reply to: mikeford12730
    When opening Options hold shift down which takes you to the Advanced Options, then go to Interface > Viewpoint defaults, this will allow you to change the default Viewpoint size.
    Lee Mullin
    Product Support Specialist
    Global Services
    Autodesk Ltd.
    New Member
    spitznagelk
    07-25-2012 01:46 PM in reply to: mikeford12730
    Lee,
    It appears that this functionality is no longer working in Navisworks 2013. Will there be a hotfix to restore it? (Or is there another workaround?) It was very useful in both 2011 and 2012 for coordination.
    Any suggestions you have would be greatly appreciated.
    Kyle
    Product Support
    08-13-2012 03:04 AM in reply to: spitznagelk
    This seems to work correctly on testing. Ensure you go into Advanced options by holding Shift when opening options. Then Interface > Viewpoint Defaults > Viewpoints Report.
    Also ensure you have SP1 installed as this is what I tested with
    usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19840757&linkID=10382102
    Lee Mullin
    Global Services
    Autodesk Ltd.
    New Member
    spitznagelk
    08-13-2012 07:17 AM in reply to: lee.mullin
    Lee,
    Thanks for the workaround. I'd mostly been using it with very large (6300 x 4300) pixel exports of single images, so using Output > Image was my preferred method (rather than exporting all viewpoints). However, your suggestion should work in a pinch.
    Kyle
