• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Navisworks
    New Member
    ulrikdanchristensen5066
    Tooltip (quick properties) hang time
    205 Views, 1 Replies
    09-04-2012 06:25 AM
    Is it posibble to adjust the "hang time" for the quick properties tooltips displayed for 3D objects in the scene view?
    I see that on my windows 7 computer the Navisworks Simulate 2012 toolstips for ribbon tools stays open as long as I keep the cursor still above the tool button. The quick properties tooltips on objects dissapear a bit too quickly and they also disappear quickly even if you do not move the cursor.
    Regards
    Ulrik
    Please use plain text.
    Product Support
    Re: Tooltip (quick properties) hang time
    09-05-2012 04:10 PM in reply to: ulrikdanchristensen5066
    Hi ulrikdanchristensen5066
    By default the time that the quick property remains displayed is 4 seconds.  However, you can override this through running the options editor in advanced mode:
    1. Open Navisworks.
    2. Click Application button and hold down the SHIFT key while you click options to open the options editor in advance mode with additional options.
    Note: These are advanced options and should only be changed if directed by support, or you are an advanced user who knows what you are doing.
    3. Expand to General > Overrides > Tooltips
    4. The default of 0 will allow for 4 seconds of the quick property display.  You can enter another value in milliseconds and the quick property should display for that duration so long as you don’t move the mouse from the item.
    5. After making the change, click OK.  You’ll need to close and reopen Navisworks for the change to be made.
    As an example, I entered 25000 and the quick property remained displayed for 25 seconds.
    Please let me know if you have further questions.  If this resolves the issue, please mark this post as resolved.
    Best regards,
    John Lipp
    Support Specialist
    Product Support
    Autodesk, Inc.
