• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Navisworks
    Valued Contributor
    Show data from an AutoCAD file
    310 Views, 3 Replies
    02-14-2013 07:45 AM
    I have a 3d model in AutoCAD. I would like to attach text data to objects in the autocad file. I need the data to display in Navisworks when I hold my mouse over the object.
    Is this possible?
    Please use plain text.
    Member
    Re: Show data from an AutoCAD file
    02-22-2013 09:55 AM in reply to: donied
    I have been able to have parametric information come across when exporting from Revit to dwfx and then opening in Navis.
    Ixath
    02-26-2013 10:03 AM in reply to: donied
    In Navis, go to GLOBAL OPTIONS -> INTERFACE -> QUICK PROPERTIES and enable those. You can use CATEGORY: NOTES to display information you enter for the objects in AutoCAD via the PROPERTIES -> EXTENDED DATA -> NOTES box.
    It might not be exactly what you're after, but maybe it's a starting point.
    Valued Contributor
    02-26-2013 11:58 AM in reply to: donied
    Thanks for you feedback. It looks like extended data is the way to go.
