• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Navisworks
    Valued Contributor
    Service Pack 1 Error
    1282 Views, 6 Replies
    12-29-2009 09:14 PM
    Not sure whether i'm the 1st one to encounter this problem.
    I'm using Navisworks Manufacturing Manage 2010.
    After installing, double clicking on the icon software pops out
    message as in attached picture--"Unable to initialize adlm."
    Is there something wrong with the service pack??
    Now i need to reinstall the software....
    Please use plain text.
    Member
    Re: Service Pack 1 Error
    01-04-2010 01:23 PM in reply to: amalynn
    I got exactly the same error after installing SP1. Using Navisworks Manage 2010 on an x64 system. However, if I start up the 32-bit Navisworks Manage it works fine - just the x64 one that will not start anymore.
    Did an uninstall and re-install fix your problem?
    Valued Contributor
    01-04-2010 06:35 PM in reply to: amalynn
    Hi John,
    Thanks for the reply on this.
    You mean you installed both 32 and 64 bit Navisworks?
    Actually i'm running on 32-bit window...
    Me and colleague encountered same problem after installed.
    Of course after reinstall it will be fine...
    Now i'm trying to install the service pack again to see result.
    We are interested more on the enhancement provided by service pack
    and to proceed installing the subscription pack...
    01-04-2010 07:36 PM in reply to: amalynn
    Problem still persist....haiz
    Valued Contributor
    01-05-2010 12:42 AM in reply to: amalynn
    I reinstall service pack with same problem...
    I only installed with Auotdesk Navisworks Manage for Manufacturing..
    It seems it's a useless Service Pack
    Employee
    01-06-2010 12:43 AM in reply to: amalynn
    Autodesk Navisworks for Manufacturing is a vertical product built on top of Autodesk Navisworks. Please ensure you use the right Service Pack for the right product. Using the baseline Service Pack on a vertical is likely to cause licensing and other issues due to different serial codes etc. in addition to most likely wiping away the changes that the vertical teams have made.
    I hope that helps,
    Jeff
    Senior Software Engineer
    Navisworks
    Autodesk Ltd.
    Member
    01-08-2010 02:23 PM in reply to: amalynn
    I am using a 64-bit Windows 7 machine - when installing Navis you get the option of installing the 32-bit and/or 64-bit versions - I installed both, and Navisworks Manage worked fine (both 32-bit and 64-bit) until installing the service pack. I now get the adlm error message when starting the 64-bit Manager - forcing me to use the 32-bit Manage (which seems to work fine) - very strange! This is the standard (non-manufacturing) Navis Manage, and I installed the standard service pack.
    I have not tried re-installing Navis as the 32-bit is working fine.
    Whatever the problem is, it seems specific to Navis - I also have AutoCAD Architecture 2010 x64 installed and that is still working without adlm errors.
    Jon Edited by: JonSmith on Jan 8, 2010 10:26 PM
