• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Navisworks
    Active Contributor
    Serious issue Navisworks XML
    131 Views, 0 Replies
    09-18-2012 12:45 AM
    Our develloper came across a strange issue with the xml reports out of navisworks. The xsd schema used in the 2012 version is the same one used in the 2013 version (8.0). But the 2013 report writes extra data about gridlocation into the xml. These generated xml clashreports are not conform the version 8.0 xsd schema! This generates errors when the xml is read into a SQL database. The point where it goes wrong is the <gridlocation>.
    Please Autodesk fix this bug!
    greetz Mark den Heijer
    Please use plain text.
