• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Navisworks
    New Member
    Revit to Navisworks Element Parameters Lost
    337 Views, 2 Replies
    10-09-2012 08:54 PM
    I have a project using Revit 2011, and our company has all series of Revit and Navisworks product from 2011 to 2013.
    When I transfer the Revit 2011 file into Navisworks 2013 file, some of the instances lost some of their element properties. I do have check the "Convert element properties" and "Convert element parameters - All" in the Navisworks settings before transferring.
    I have also tried using other version of the software or open the revit file direcly in Naviswork 2013, but none of the methods work.
    Is there anything I am doing wrong? The file is attached.
    Please use plain text.
    Valued Mentor
    dennis
    Re: Revit to Navisworks Element Parameters Lost
    10-10-2012 05:09 AM in reply to: Hayson.C
    I checked your file and I think what you need to do is change the "selection resolution" of the fitting when you select it.  I first got the same amount of properties you show, with the "selection resolution" set to "Last Object".  I then changed to "First Object" and receive alot more data.  Right-click on the fitting to set the "selection resolution".
    New Member
    10-11-2012 01:41 AM in reply to: dennis
    Dear Dennis,
    Thanks! Everything is OK now.
    Best regards,
    Hayson
