Autodesk Navisworks
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
RE: exporting part of .nwd file to other file
- Highlight
- Email to a Friend
- Report Inappropriate Content
I have an sample .nwd file which I am working on and I want to use the elements (viz. the .dwg drawings) in new .nwd files but I am not able to export them individually.
If I use append or merge command, it imports all the .dwg or revit files (even if I hide them). Can someone please suggest any possible option.
I am trying to export a truck model into a construction site to make an animation.
-vvsoni
Re: RE: exporting part of .nwd file to other file
- Highlight
- Email to a Friend
Which application are you using to make the animation?
Assuming this is Navisworks then you would need to hide the model and ensure your viewpoints use the 'Hide/Required' Option which will respect hidden items. More information on this can be found in the help.
If you are looking to export part of the NWD for use in another application then you may have problems as this is something Navisworks is not intended to be used for. You can use FBX or DWF export but you may have varying results as I believe they do not respect hidden items.
If you look at the selection tree you should be able to look at what the original files were that the NWD was created from. You should then go back and try and find the native CAD models.
You may want to use Autodesk SEEK or Google Warehouse to get an individual element for the animation, such as cranes, doors etc.
- Highlight
- Email to a Friend
I was making the animation in Naviworks only. But thanks a lot for the information. I did not know about google warehouse or autodesk seek at all. It's really cool stuff.
Also hiding the other features and exporting as fbx helps.
