• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Navisworks
    StephenHenshall1260
    Accepted Solution
    Publish using the Batch Utility (Simulate 2012)
    467 Views, 12 Replies
    02-07-2012 05:15 AM
    Is it possible to publish an nwd file via the Batch Utility?
    I currently generate a new model via the Batch Utility Scheduler but for security reasons, I need the file to be locked after 24hrs.
    I can manually publish the file with these settings but I need to automate the file creation.
    Please use plain text.
    Re: Publish using the Batch Utility (Simulate 2012)
    02-08-2012 12:17 AM in reply to: StephenHenshall1260
    In the VB examples there is an example that does just that:
    C:\Program Files\Autodesk\Navisworks Simulate 2011\api\COM\examples\AUTO_08\Auto_08.vbs
    (I suppose it is also included in the 2012 version)
    Just open with Notepad and read it.
    This can be launced from a command line
    and thus by a scheduled CMD-file.
    I had to modify it to get rid of the password and expirying date...
    StephenHenshall1260
    02-08-2012 02:46 AM in reply to: Patrick_Aps_9121
    Patrick,
    Works a dream, many thanks.
    StephenHenshall1260
    02-08-2012 03:34 AM in reply to: Patrick_Aps_9121
    Is there a way to set the date to increment automatically?
    eg todays date + 1
    02-08-2012 10:19 PM in reply to: StephenHenshall1260
    Within the VB code, surly, but I don't know how.
    Product Support
    02-10-2012 09:08 AM in reply to: StephenHenshall1260
    Try the Navisworks API forum
    http://forums.autodesk.com/t5/Autodesk-Navisworks-API/bd-p/600
    Lee Mullin
    Product Support Specialist
    Global Services
    Autodesk Ltd.
    StephenHenshall1260
    02-15-2012 03:56 AM in reply to: lee.mullin
    Solution found,
    If you replace the expiry argument with the following code, the published file has a onw week lifespan.
    arg_expiry = dateadd("d", 7, Now() )
    New Member
    OLLE_86
    03-15-2012 09:01 AM in reply to: StephenHenshall1260
    Do you know if there is a way of creating a batch that uses the publish option "embed database properties" instead of expiration date?
    StephenHenshall1260
    03-15-2012 09:21 AM in reply to: OLLE_86
    Spoiler
    Ollie. I looked at trying to change some of the settings at the bottom of the publish dialogue but had no success. I think it was the spces in the attribute names that caused the problem (together with my lack of vb knowledge). I tried with single and double quotes but couldn't get it to work.
    StephenHenshall1260
    03-15-2012 09:23 AM in reply to: OLLE_86
    Sorry, not sure what happened to my last reply
