• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Navisworks
    Problems with MHT-reports
    475 Views, 3 Replies
    08-28-2009 12:25 AM
    Hi!
    I'm working with NavisWorks 2009.
    Everything works great when I'm saving reports first as veiwpoints and then as Html. And after that I save my Html as MHT.
    But...
    When I try to mail or upload the MHT-files to an external server, the images disappear (cannot be read).
    Can someone tell me why this happens and what I can do to make it work!?
    SaraQ
    Please use plain text.
    Product Support
    Re: Problems with MHT-reports
    08-28-2009 07:13 PM in reply to: SaraQ
    Hi Sara,
    When exporting a Viewpoint or Clash HTML report, the jpg images are placed in the same folder as the HTML file. In the HTML file, the images are linked by only their filename. These are relative paths to the file, and if you were to move the HTML file to another folder without the image files, the images would be missing when viewing the HTML file. So long as you keep the images and HTML files together when you move them, the HTML file will link to the images.
    When you resave the HTML report to an MHT file in Internet Explorer, the relative paths to the images are changed to absolute paths in the MHT file. The paths point to exact location on your local machine. Importantly, since the paths are absolute paths to the images on your computer, these links will break one you move the MHT file to another machine, namely your server since the directory structure will be completely different.
    Rather than resaving to an MHT file, I suggest uploading the images and the HTML file to your server, placing them in the same folder.
    Product Support
    Also note, there is a known defect in the 2010 version of Navisworks Manage in which the paths to the jpgs images are absolute paths in HTML reports. This will cause the same issue if you move the HTML report to another machine. Edited by: jlipp on Aug 29, 2009 2:18 AM
    09-02-2009 02:07 AM in reply to: SaraQ
    Hi
    Tanks for your reply! The thing is, that there are no problems with MHT-files created from another .nwf. I can put them anywhere! That's why I think there is something with the settings in NW.
    Are you sure about saving as MTH changes the path to absolute? I rather think the pictures are inserted.
