• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Navisworks
    Valued Contributor
    bbrown
    Opening Revit files natively
    382 Views, 2 Replies
    08-26-2012 08:51 PM
    I've only briefly played with opening Revit files natively in Navisworks 2013, so if the answer to this is obvious I apologize. The samples I used were some what complex models and all of the elements where brought in. There did not seem to be any sort of filter. Is there a way to have it only open elements from one particular 3D view defined in Revit?
    Please use plain text.
    Product Support
    Re: Opening Revit files natively
    08-28-2012 12:35 AM in reply to: bbrown
    Hi bbrown,
    If you set filters in a particulat 3D view in Revit to hide some objects, and want to only import the visible elements in Navisworks when opening this Revit files, you can try steps below:
    1. Open Revit file in Revit, then rename the particulat 3D view name to Navis.
    2. Launch Navisworks, in Options dialog- -File Readers- -Revit, in right panel, set "Convert" field to Navisworks view, click OK, see attachment "NW1.JPG".
    3. Open the revit file in Navisworks, then it will only import the elements visible in view Navis of Revit.
    Thanks.
    ______________________________________________________________
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
    Lei Lan
    Support Specialist
    Product Support
    Valued Contributor
    bbrown
    08-30-2012 05:05 AM in reply to: lanl
    Awesome, that is just what I was looking for. One more question, Is it required to be called "Navis" for this to work?
