• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Navisworks
    New Member
    Navisworls 2013 Item Proprties for PDS Piping models.
    337 Views, 3 Replies
    09-21-2012 06:43 AM
    Navisworks 2013 does not display PDS Component data for PDS piping models (MicroStation v7.0 dgn files), even though it appears to be reading the tag (.drv) files. It does display data for equipment models and strurtural models.
    Has anyone experienced this?
    Please use plain text.
    Re: Navisworls 2013 Item Proprties for PDS Piping models.
    09-25-2012 01:50 AM in reply to: paulgs06
    not exaclty,
    but when you use the Selection Tree -> Properties -> PDS component data
    and you click a + sign,
    all flavours of Navisworks 2013 crached.
    Perhaps this is solved with ServicePack 2, but for PDS data, I remain on the 2012 versions.
    New Member
    10-05-2012 09:03 AM in reply to: paulgs06
    I did find a workaround. If I deleted the PDS tag files for piping (*.drv) and recreated them, then the data appeared in Navisworks. Don't know why this occurs.
    10-07-2012 10:40 PM in reply to: paulgs06
    Did you delete the NWC files of those models also ?
    I had the expericene in the past that when DGN files did not change of date, but DRV files did, then NWC were not updated and PDS data was not showing up. In this scenario, deleteing the NWC files then re-create the drv files and then opening the NWF file to force the recreatuion of NWC files did the trick.
