• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Navisworks
    Active Member
    sawan.sakale
    Navisworks or 3D Max?
    1507 Views, 17 Replies
    07-01-2011 08:27 PM
    Hello Everyone,
    In terms of animation which of Navisworks or 3D Max is better. Can you please put down some reasons?
    Thanks.
    Please use plain text.
    Product Support
    Re: Navisworks or 3D Max?
    07-04-2011 02:40 AM in reply to: sawan.sakale
    It depends on what you want to do. Navisworks tends to be used mostly for creating simple quick animations, such as demonstrating a construction sequence. Whereas 3DS Max would be used for more complex animations and rendering.
    You can get great results in both, this for example is a construction sequence in Navisworks
    This is a great article about creating smooth animations you may find useful.
    http://beyonddesign.typepad.com/posts/2011/06/creating-smooth-animations.html
    Lee Mullin
    Product Support Specialist
    Global Services
    Autodesk Ltd.
    07-05-2011 05:00 AM in reply to: sawan.sakale
    To make it simple:
    if the technical contents is more important than the good looks of the animation,
       If you need to measure, see if something fits, see if everything is accessable....
       and end-users do not bother what color the walls have, as long as they are on the right location...
       if you want to deliver a file where end-users can roam around freely...
       and where custumers need to command and give feedback on the model
    use NavisWorks
    if the look and feel of the animation is more important than technical correctness,
      if your end product should be an filme and nothing else
      if the materials used must have the exact look in the animiation
    use Max.
    07-20-2011 08:07 AM in reply to: sawan.sakale
    Hopefully this is the right place to ask this question.
    If you have a Navisworks file is there anyway to import into 3D Studio Max.
    I am asking for another person, so if specifics are needed I can check with him.
    Thank you
    Rick
    *Expert Elite*
    DarrenP
    07-20-2011 09:18 AM in reply to: anadarko
    you can export out of navisworks to .fbx file and import that file into 3ds max
    depends on the version of navisworks
    New Member
    wahababd
    07-28-2011 03:42 AM in reply to: DarrenP
    I have Navisworks Freedom 2012 and want to open .nwd file in 3D Max. Please guide me how can i export .fbx for 3D Max. I am not familiar with Navisworks and could not find any export option in it :smileysad:.
    Thanks in advance.
    Abdul
    Product Support
    07-28-2011 03:59 AM in reply to: wahababd
    Hi Abdul,
    Navisworks Freedom does not allow export of models, only viewing of NWD and DWF files.
    You will need Navisworks Simulate or Navisworks Manage 2012 to be able to export to FBX. More information can be found here
    Lee Mullin
    Global Services
    Autodesk Ltd.
    alatriste15
    09-09-2011 05:43 PM in reply to: lee.mullin
    I have only used timeline simulation feature to make a export movie. but recently i have seen your animated construction autodesk movie on youtube. it is amazing. I liked the animation which you had used in your movie. as an intermediate naisworks manage user, I would like to know how to use this animation tools in your video. so far I have only used timeline simulate in order to create an movie. I am not familiar the animation part in navisworks manage 2012.
    I would be grateful to you if you could provide any tutorial or actual movie for your animated construction video on youtube.
    I  desperately need your those kinds animation technics for my building construction project.
    thanks
    Active Member
    sawan.sakale
    09-10-2011 12:24 PM in reply to: alatriste15
    Same Question from my side too. I was amazed to see that youtuube video. Any help will be highly appreciated.
    Thank you.
    Active Member
    11-03-2011 09:04 AM in reply to: sawan.sakale
    The construction sequencing is amazing - I would like to see it export to 3DS max in order to achieve higher resolution, greenscreening, and photorealism.  The rendering time in Navisworks is painfully long, and doesn't allow for render farm usage either.
    We are doing a minute-long sequence in Navisworks and it is taking almost a full week to render.  Our client is seeing it as a waste of time as the animation quality is so poor.
