• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Navisworks
    Distinguished Contributor
    Navisworks Manage Service Pack 1
    374 Views, 5 Replies
    08-24-2012 11:02 AM
    I have navisworks installed as part of Building Design Suite Ultimate R2013. I cannot install the service pack update from the downloads page. I'm getting the error below. Any Help would be apprecitated.
    Please use plain text.
    Product Support
    Re: Navisworks Manage Service Pack 1
    08-27-2012 03:35 PM in reply to: iam4phils
    HI iam4phils
    Did you download the 64-bit version of the hotfix on a 32-bit machine or vice versa?  This same error occurs in this same situation.
    This error will also occur if you downloaded the patch for Simulate, but have Manage installed  as Building Design Suite Ultimate 2013 includes Manage.
    Please try re-downloading from the page it may be the wrong version or maybe the file was only partially downloaded or corrupted during download:
     - http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19840757&linkID=10382102
    Best regards
    John Lipp
    Support Specialist
    Product Support
    08-28-2012 05:21 AM in reply to: john.lipp
    I believe I have done everything correctly. The only thing I couldn't find was the download for the program in the package "Building Design Suite Ultimate". So I downloaded the patch in the Navisworks section of the website.
    DarrenP
    08-28-2012 05:43 AM in reply to: iam4phils
    my navisworks 2013 sp1 file size is 344,227 kb yours is 296,179 kb in size it doesn't seem its downloading the whole service pack
    08-28-2012 06:54 AM in reply to: DarrenP
    Thanks, that was it. Something was blocking the whole file from downloading. My IT dept was able to download and the file was the correct size and installed fine. Thanks for the help/
    New Member
    robertoga
    Re:Navisworks Simulate Service Pack 1+2 install Fail
    12-10-2012 11:24 AM in reply to: DarrenP
    Hi Darren
    I´m having a similar case with both service packs and I´ve checked the size of thefully downloaded both sp1 and sp2.
    As you can se from the attachment I´m getting some kind of instruccions for the windows installer at the command line.
    Is there something wrong with my windows installer?
    I´m running W7 64 bit
    Thanks in advance
    Regards
    Roberto
