Hi, are you saying its the machine thats incompatible with the application? What particular machine is having this sort of issue? I have no idea in debugging the attached files, I hope you would take a look at the errors generated. Thanks.
We have the same issues with Simulate 2011, on one computer it is not starting. After the splash screen is shown it just kills the roamer.exe. It seems to happen on all users on the computer so it is profile independent.
I reinstalled the Framework and killed all user registery settings and got it to work yesterday evening. but then again this morning it does not work anymore.
What a piece of crap, it can't be an acceptable solution to be forced to reinstall .net framework and the software each and every day, it just takes too long.
I have been a Navisfan but I have to say starting from 2010 (when you sometimes got corrupt files and had to delete some folder) and now 2011 even worse that require newinstalls of everything even .net framework it just annoying!
Edit: There has to be a flaw in the software that corrupts files (or either a virus, has to check the computer) but I have difficulties believing it a virus when this problem occures very often it seems...
/Markus
I know this is a super old post, but you guys are not going to believe what I just figured out:
VAULT WAS THE ISSUE!!! (and possibly add-in components)
In some newer versions, (particularly 2014) if Navisworks opens fine as an RTM install but starts crashing after installing ANY kind of Navisworks update, you might get an error that points to a .NET failure in the Windows event log that looks something like this:
Application: Roamer.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.IO.FileNotFoundException
*(sometimes the upper line said something else like "System.TypeInitializationException")
Stack:
at Autodesk.DataManagement.Client.Framework.Vault.Library.RegisterExceptionParserServices()
at Autodesk.DataManagement.Client.Framework.Vault.Library..cctor()
Exception Info: System.TypeInitializationException
at Autodesk.DataManagement.Client.Framework.Vault.Library.Initialize()
at Connectivity.Common.Vault.VaultCommon.Initialize()
at Autodesk.Navisworks.VaultPlugin.Application.VaultPluginApplication.Initialize()
at Autodesk.Navisworks.VaultPlugin.Application.VaultPluginApplication.get_Instance()
at Autodesk.Navisworks.VaultPlugin.VaultCommandHandlerPlugin.IsSelfEnabled()
at Autodesk.Navisworks.Api.Plugins.PluginRecord.CreatePlugin()
at Autodesk.Navisworks.Api.ApplicationParts.ApplicationPlugins.LoadPlugins()
at Autodesk.Navisworks.Internal.ApiImplementation.ApplicationImpl.LoadPlugins()
at NetRoamer.Program.MainImpl(System.String[])
at NetRoamer.Program.Main(System.String[])
And I'm pasting this RAW so it's easy for everyone to search.
The weird thing is, it didn't even look like this until screwing around with multiple versions of .NET framework, resetting the Autodesk profile, and deleting some odd components that didn't seem relevant. For 2 days the most I could find was msiexec.exe junk errors and meaningless number strings in repetitive log entries that never pointed to anything specific. Next I took a suggestion from an old post with a similar problem here: https://blogs.rand.com/support/2014/02/autocad-2014-gives-errors-after-installing-the-navisworks-201...
It explains that, in many instances, crashes are caused by the Navisworks updates essentially being half-baked, since they DON'T account for the exporter components offered by the Navisworks installer as an optional extra. The exporter components need to be updated with a separate hotfix. Nice one, Autodesk.
After I went through all of that, the log files started to change, and this time stayed consistent (as posted above) no matter what adjustments or other workarounds I tried, and all signs pointed to one thing, referencing some "plugin" as faulty... Vault. After uninstalling vault, my old install of NAVMAN with the new SP2 update applied finally opened without further errors. I hope this helps someone.
*EDIT: I double-checked the process for my solution, and it should be noted that uninstalling the "Factory Design Utilities for Navisworks 2014" also helps, due to incompatible versioning after running the NAVMAN update.
