• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Navisworks
    New Member
    Navis Works Animator - render frames output and moving multiple keyframes
    276 Views, 1 Replies
    02-04-2013 11:29 AM
            I've been using the animator in Navis Manage for fly-bys on several projects. One of the most frustrating issues with animator is the fact that you can’t select multiple key frames and move them along the timeline.  Every project I’ve rendered has crashed in the middle of rendering.
            I always render individual frames and post composite using After Effects.  In 3D Studio, not only can you scale and move multiple key frames, but you can output a rendering based on the start and end of key frames, i.e. render from 258 thru 3060. This is very useful when a rendering crashes because all you have to do is render the frames from where it crashed to the end.
           It seems that the Navis developers need to take some interface and functionality from the Maya and Max groups.  I know what you’re thinking.  If 3D Studio is so great why not just render it using that?  Well if anyone has ever tried to import a full 3D building with all MEP trades into MAX, you would know the answer to that question?
    Autodesk Navis Developers, I’m pleading with you to add some enhancement to the animator feature please!!!!
    Please use plain text.
    Product Support
    alan.quinn
    Re: Navis Works Animator - render frames output and moving multiple keyframes
    02-06-2013 10:47 AM in reply to: jasonschaat
    Most is not all of what you posted is on a wish list or on development radar. I suggest leaving feedback at the below link. Information gathered is used to improve the application.
    Product Contact Link: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
    Thanks for posting.
    Alan Quinn
    Support Specialist
    Product Support
