• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Navisworks
    Distinguished Contributor
    RNDPIS
    Navis Export Problem
    240 Views, 2 Replies
    10-03-2012 10:47 PM
    While exporting revit model of a selected portion (Croped by section box), unwanted element appearing in the navis file. We have attached two screenshots for your easy reference.
    Please use plain text.
    Valued Mentor
    dennis
    Re: Navis Export Problem
    10-04-2012 06:23 AM in reply to: RNDPIS
    Checking the obvious first, are your settings for export "current view" and is your section-box view the active view?  After that, are those items that shouldn't be there in a link?  Links do not get cut by the section box on the export.
    RNDPIS
    10-04-2012 09:31 PM in reply to: RNDPIS
    Thanks for your quick response. The export setting is "current view" and section box view is in active mode also there is no link. Can you suggest us any other possibilities to solve this problem. We are in real hurry.
