• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Navisworks
    Moving or transforming Objects
    360 Views, 3 Replies
    12-14-2012 03:11 AM
    I want to move some object, using the transform.
    Save this positinon as a viewpoint
    Move the objext somewhare else, using the transform
    and save that again,
    so that we can evaltuate the differen options later,
    using viewpoints
    Is that possible ?
    it looks like transforms are done for the whole file and not saved per viewpoint.
    Has anyone a workaround ?
    kind regards.
    Please use plain text.
    Product Support
    Re: Moving or transforming Objects
    12-17-2012 05:46 AM in reply to: Patrick_Aps_9121
    Hi Patrick,
    The best way to do this would be to model the object in the original CAD application multiple times in the various locations you would expect it to be. Then use viewpoints to hide the object in the various viewpoints, you would need to ensure you have Hide/Required checked in the Options > Interface > Viewpoint Defaults.
    Lee Mullin
    Product Support Specialist
    Global Services
    Autodesk Ltd.
    12-17-2012 10:09 PM in reply to: lee.mullin
    Yeah, I aready thought of appening "the CAD file that holds the item to be moved" multiple times and show only one in each viewpoint. This avoids messing up the CAD file and the database connected to it.
    I was wondering if something with animations could do this creation of "Stills"
    Product Support
    12-19-2012 02:43 AM in reply to: Patrick_Aps_9121
    Potentially yes.
    Using the tips in this blog post about creating smooth animations you could create an animation that has 6 keyframes, if you made it 6 seconds long and exported as images at 1 frame per second, you would have 6 images that have each keyframe. These obviously would be static images but you could always move to the different keyframes if you wanted to review them in the 3D environment.
    Lee Mullin
    Global Services
    Autodesk Ltd.
