• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Navisworks
    New Member
    Missing objects (cylinders) from a DWF file
    251 Views, 1 Replies
    11-18-2009 11:01 AM
    I try to load a DWF file produced with PDMS and all the cylinders are missing !
    It is ok for rectangular objects.
    Since pipes and many fittings are made out of cylibders the result is quite disapointing...
    When I open the same file with "Autodesk Design Review", there is nothing missing !!!
    Does anyone has a clue on why this happens ???
    Please use plain text.
    Employee
    Re: Missing objects (cylinders) from a DWF file
    11-24-2009 07:11 AM in reply to: emaschas
    Hiya.
    This is a known issue that we should have fixed in our 2011 release. As a workaround in the time being, you can disable parametric primitives. This setting can be found under Global Options -> Model -> Performance -> Create Parametric Primitives.
    Hope this helps,
    Michael
