Autodesk Navisworks
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Missing objects (cylinders ) from a DWF file
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
252 Views, 1 Replies
11-18-2009 11:01 AM
I try to load a DWF file produced with PDMS and all the cylinders are missing !
It is ok for rectangular objects.
Since pipes and many fittings are made out of cylibders the result is quite disapointing...
When I open the same file with "Autodesk Design Review", there is nothing missing !!!
Does anyone has a clue on why this happens ???
Re: Missing objects (cylinders ) from a DWF file
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-24-2009 07:11 AM in reply to:
emaschas
Hiya.
This is a known issue that we should have fixed in our 2011 release. As a workaround in the time being, you can disable parametric primitives. This setting can be found under Global Options -> Model -> Performance -> Create Parametric Primitives.
Hope this helps,
Michael
Hope this helps,
Michael
