• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Navisworks
    New Member
    Missing Pipes in Navisworks NWD File
    265 Views, 5 Replies
    07-25-2012 08:55 AM
    I'm have trouble viewing pipe in Navisworks. The model I'm trying to veiw was drawn in Plant3D.  All layers are turned on and pipe looks fine in model, however when I open the drawing as DWG file in Navisworks some of my pipe is missing.  Any ideas?
    See pictures for reference.
    Alex Edwards
    Please use plain text.
    Active Member
    check-kay.wong
    Re: Missing Pipes in Navisworks NWD File
    07-27-2012 07:34 AM in reply to: aedwards83
    i think i have the same problem.
    08-13-2012 06:12 AM in reply to: check-kay.wong
    same problem here but still no solution?
    Active Member
    check-kay.wong
    08-13-2012 06:17 AM in reply to: snijdam
    They only solution i found is to re-save it (DWG file) with Autocad, not with a 3rd party soft.
    is a turnaround.
    New Member
    08-13-2012 01:39 PM in reply to: aedwards83
    I recently found a solution to this problem.
    For the plant I am working on I created a master file that contains all x-refs for the project.  Within the master drawing everything was visible (Pipes, Tanks, Equip, etc.).  I saved the file and opened it in navisworks.  When opening the dwg file in navisworks I noticed that various pipes were missing that were shown in the model.  To fix this I returned to the Plant3D and opened the individual drawing at the location where the pipe was missing and found that the layer was turned off in that drawing.  I turned the layers back on, reloaded the xref in the master drawing and opened the file once again in navisworks.  All the pipe is now visible.
    The key for me was getting each drawing opened up and turning all layers on.  Just because you can see the linework as xref data doesn't mean it will show up in navisworks.
    Active Member
    check-kay.wong
    08-14-2012 04:41 AM in reply to: aedwards83
    i'll keep that in mind. thanks
