• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Navisworks
    New Member
    MEP Pipe sizes in Navisworks
    296 Views, 2 Replies
    12-16-2009 03:53 PM
    Our engineers use Navisworks to review models and they are unable to see what size a pipe is modeled to.
    Is it possible for Navisworks to list a Pipe size that was modeled using MEP? We are using MEP 2008 and Navisworks Review 2009.
    Thanks in advance
    Please use plain text.
    New Member
    Re: MEP Pipe sizes in Navisworks
    12-17-2009 06:41 AM in reply to: sethfranklin4567
    We only have NavisWorks Manage in our office so this answer is coming from that perspective. You should be able to select the object in question using the Selection tool and then open your Properties dialog box. The size of the pipe should be listed in the Properties dialog box once the item is selected. I hope this helps.
    Employee
    12-17-2009 08:59 AM in reply to: sethfranklin4567
    If this property is something you want quick access to all the time, you can customize Smart Tags to include it using the Global Options interface. Then with Smart Tags turned on, you'll get a tooltip with the information whenever you move the mouse over an object.
    Tim Wiegand
    Software Architect
    Navisworks
