• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Navisworks
    Active Contributor
    How to include a script in Timeline? Need your help!
    186 Views, 3 Replies
    11-13-2012 11:43 PM
    I am working on a timeliner simulation in Navisworks.
    But I have a question on how to use script, I create a script,  a gate will open if the truck is closing to this gate(I have created a gate auto open animation), my script is On Hot Spot Event type, if the truck is moving to the position withing 3 meter from the gate, then gate animation will be triggered.   Also, truck moving is an animation.
    Question: 1) Do I need to include script in the Timeliner and setup Start time and EndTime.
                     2)Do I need to include the Gate Animation and Truck Moving Animation in Timeliner and setup Start time
                        and End Time.
    Does anyone can give me a guide on how to create a script and how to use it?
    Jian
    Please use plain text.
    Product Support
    fernanda.firman
    Re: How to include a script in Timeline? Need your help!
    11-21-2012 11:16 AM in reply to: li71we
    Kindly refer to the document below.
    http://aucache.autodesk.com/au2009/sessions/5204/AU09_SpeakerHandout_CR122-1.pdf
    Hope that helps.
    Fernanda Lima Firman
    Revit Support Specialist
    Revit Clinic
    If this helped solve your issue - remember to 'accept as solution' to help others find answers.
    12-04-2012 04:30 AM in reply to: li71we
    That is very good guide but I believe the question is how to use the hot-spot trigger in a timeliner animation and the answer is you can't, they just don't work during a timeline animation.
    The workaround is to link the gate animation directly to a task in timeliner. This works because your truck will always arrive at the same known time in timeliner.
    Hotspots are ideal fore when you're moving around the model or running a viewport animation and need an event based on proximity.
    Product Support
    fernanda.firman
    12-04-2012 09:05 AM in reply to: li71we
    Thanks for posting!
    Revit Clinic
