• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Navisworks
    Distinguished Contributor
    How to check the elevation (z-coordinate) of an element or a point?
    213 Views, 1 Replies
    10-12-2012 10:29 AM
    Is there an easy way to check the elevation (z-coordinate) of an element or a point. The elements in the model that I am working with do not have this attribute.
    Please use plain text.
    Valued Mentor
    dennis
    Re: How to check the elevation (z-coordinate) of an element or a point?
    10-12-2012 11:46 AM in reply to: PatrickEC
    Measure tool is it.  You don't have an ID point like AutoCAD.  In NW, you will need to have the Measure dialog box open, then pick a couple points as if you wanted the distance between the two.  In the Measure dialog you will see the absolute point values and then the difference values.
