• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Navisworks
    New Member
    Failed SmartSolid, Failed Cell
    377 Views, 2 Replies
    12-07-2009 07:48 AM
    Hello, I am having trouble opening a MicroStation DGN file with NavisWorks. The problem is that complex solids are not brought into NavisWorks. They are simply omited when I open the DGN file. I know that elements are omitted because I can go to View > Scene Statistics and it tells me that there are failed smartsolids and cells. I get a description as shown below. I usually locate the offending elements and drop them to surfaces, and that seems to fix the problem. It is a real pain to try and located those elements. It's a trial and error process to look for elements that are complex and guess that they are the elements that fail. My question is how can I locate the omitted elements easily? I might expect NavisWorks to create a log file showing the location or element ID's of the failed elements, but I cannot find any such file. Any recommendations? Thanks.
    SCENE STATISTICS
    Triangles, Lines and Points: 2658403
    Bounding Box: (8238.87,19976.8,-58.75),(9923.76,21355.6,38)
    2008-052 Str Foundations.dgn
    Converted 3928 Cell
    Converted 779 Line
    Converted 2 Shape
    Converted 2546 Complex Shape
    Converted 67 Ellipse
    Converted 2076 Surface
    Converted 5128 Solid
    Converted 866 Cone
    Converted 23 B-Spline Surface
    Converted 3660 SmartSolid
    Failed 163 Cell
    Failed 163 SmartSolid
    Please use plain text.
    Employee
    Re: Failed SmartSolid, Failed Cell
    12-08-2009 04:52 AM in reply to: markmaresko6100
    If you have access to Microstation, the best way of bringing DGN files into Navisworks is to export from Microstation as an NWC using the Microstation export plugin. The Microstation export plugin has access to the Microstation API and is able to handle complex elements that the reader has trouble with.
    You can do a DGN to NWC conversion using Microstation via the command line, so the process can be automated. Navisworks comes with a sample perl script for converting a whole directory of DGNs.
    There is no additional logging for the DGN reader that will show the location or element IDs of failed elements.
    Tim Wiegand
    Software Architect
    Navisworks
    New Member
    12-08-2009 05:43 AM in reply to: markmaresko6100
    That worked. Thanks! For others benefit, here is what I did. I opened MicroStation and loaded the NavisWorks export plugin using the keyin "mdl load nwexport6". Then keyin "nwdout" or "nwcout". You will then export the NavisWorks file from within MicroStation.
