• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Navisworks
    Active Member
    abhityagi
    Export file in Maya
    84 Views, 1 Replies
    04-26-2012 09:19 PM
    I have a problem in navisworks file export . my plant is heavy (navisworks)  and i want to import in maya . so pls tell me how can i do this. should i use poly trasfer plugin for low mesh or any option in navisworks manage. and how do work export system in globel option in navis works .
    Please use plain text.
    Active Contributor
    Re: Export file in Maya
    05-02-2012 07:50 AM in reply to: abhityagi
    with massive dataset sizes, i'd suggest you save yourself the headaches and just render your images/movies directly from Navis/Presenter.
    dp
