• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Navisworks
    Valued Contributor
    Duct Flow values from Revit reporting Wrong
    184 Views, 2 Replies
    06-04-2012 08:07 AM
    I am troubleshooting an issue whereby some Revit MEP element parameters report inproperly in the Navisworks Properties palette. For instance, the "Flow" parameter of a Duct instance in the Revit file (150 CFM) is reporting (2.50 ft3) in NVM 2013. This is happening across all readable formats which include reading the native RVT and DWFx/NWC exports. I have the File Reader for Revit set to Convert element parameters for Elements but, not to Convert element properties hoping that this would retain the original Revit data.
    When I open the DWFx in Design Review 2013, the Flow reports properly. Is this a bug in NW?
    Please use plain text.
    Product Support
    Re: Duct Flow values from Revit reporting Wrong
    06-25-2012 06:15 AM in reply to: Bill.Knittle
    Hi Bill, can you please upload this model and we'll pass it to development?
    Lee Mullin
    Product Support Specialist
    Global Services
    Autodesk Ltd.
    Valued Contributor
    06-30-2012 07:23 AM in reply to: lee.mullin
    Lee, can I log this through Autodesk Support and post the models there? I would rather not post the customer's model in the forum. How could I make sure it gets to you specifically if I do?
