Autodesk Navisworks
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Drawings from NavisWorks Freedom
- Highlight
- Email to a Friend
- Report Inappropriate Content
Hi
I plan to import models fron Revit (construction and arch), MagiCAD (Electrical installations, pipes) and TEKLA (Steel) into NavisWorks Simulate.
Is there a way to produce Drawings from NavisWorks that contain 1) all these CAD drawings in one? 2) i e produce a drawing with Construction + Electrical installations (as a selected choice)?
If not, is there a better way to maybe produce total (or selectable drawings) from 3 CAD systems with a viewer ?
Regards
Stein
Re: Drawings from NavisWorks Freedom
- Highlight
- Email to a Friend
DO you mean produce 2D drawings from Navisworks? At this moment this isn't supported.
You can create a 3D model from all the files in Navisworks, but there is no ability to turn these into 2D sheets from any of our export routes.
Use Navisworks Exporter in Revit
Either import MagiCAD model with Object enabler installed or export from native application
TEKLA model should be exported to IFC then this can be imported to Navisworks.
Navisworks Exporter utility can be found here for machines without access to Navisworks Simulate or Manage
- Highlight
- Email to a Friend
Tekla can export 3D DGN also, that NavisWorks can read. This results in smaller NWD files than the IFC way, but less information about the steel profiles used.
With NavisWorks you can create a perendicuar view and slice that to create a JPG file that views the model like a floor plan or 2D section would, but it is not a drawing, just a JPG file....
If AutoCAD could reference and slice NWD files however, like I already requested, the combination of AutoCAD and NavisWorks could do this.
Or maybe just load the 3D DGN file from Tekla into Revit and see how far you get...
- Highlight
- Email to a Friend
This I would like very much, put it in Navisworks Manage and you get some extra bucks. For large coordination projects where the models comes from a variaty of cad systems, it would be very nice to be able to create 2d line plan/section drawings from the Navisworks 3D view.
In larger coordination projects there are very few software that can handle the models as good as navisworks, generating 2D linework from the view should not be that difficult.
Please add to development list, I promise to buy some more licenses!
/Markus
- Highlight
- Email to a Friend
Do you want to give us some feedback via this page about your workflows and how this might help?
http://usa.autodesk.com/adsk/servlet/index?siteID=
- Highlight
- Email to a Friend
I realize this is really old, but it's the only reply I got googling. Has this been addressed yet? Being able to export 2D CAD files or any other sheets to scale would be very, very helpful.
- Highlight
- Email to a Friend
And very, very dangerous. Not to mention complicated - your sheet drawings are probably different from ours, are probably different from others. Best to do it in the applicable software (Revit, Plant3D, Civil3D, Inventor...) which is designed from the get-go to produce those drawings properly, without polluting Navisworks with kinda-sorta tools for each and every application under the sun. Lets keep it as it is - a coordination tool, not a drafting tool.
If you are going to fly by the seat of your pants, expect friction burns.
Adopt. Adapt. Overcome. Or be overcome.
- Highlight
- Email to a Friend
You must be an architect. I'm not interested in your sheets or numbering as they are pretty much irrelevent to what I'm doing on the construction side once the trade contractors have prepared their models. In fact, the workflow is irrelevent to this discussion. If it can't be done currently in Navisworks, it should be added.
I'm actually not interested in doing this fron Freedom, but Manage, but this is the only place I could find this utility being discussed.
When I get models from multiple trades, all generated from different programs, and spend the time to bring them all into Manage to coordinate, issue a report, get new models, re-import and re-run to check that they corrected the clashes, it's asinine to have to jump out to a seperate program to generate contract-required 2D coordinated drawings. I should be able to take views, to scale, within Manage to satisfy that requirement, not have to re-compile everything into some separate program, or push it out to DWF to do it. That is all a time eater.
If YOU don't require this functionality, don't use it. Autodesk adding it to help someone else in the industry shouldn't affect you at all, anf frankly shouldn't be at all difficult for them to do.
- Highlight
- Email to a Friend
Not architect, process piping industry. So when I say "bad" I don't mean ugly or a low ceiling. I mean five-o'clock news BOOM-toxic cloud-dead people bad. While its fine to get general dimensions and visualizations for reference purposes, we, our clients, and our fabricators have zero interest in anybody being able to generate construction drawings from Navisworks which can conflict with the actual engineering drawings. And as a CAD admin I have zero interest in bloating up the program with features which can, and have, been done in other applications.
"Yes" and "no response" aren'the only valid opinions. Sometimes you've gotta raise the hand and say "I don't think so, Tim."
- Highlight
- Email to a Friend
So regardless, you're design-side?
Look, arguing about whether or not you think these drawings should be produced is silly. They WILL be produced, they HAVE BEEN produced in the past, and they WILL BE produced more and more in the future. I am seeing more and more government contracts that require coordinated drawings as a submittal. Federal, state, and local/county. So the choice becomes to either be able to produce that submittal out of Navisworks, with all the correct files that were used for the coordination, and the drawings that will produce the drawings that will be used for construction, or to start over from scratch in a program that allows me to produce the required submittal. Like it or not, the trade contractors are going to take their final coordinated shop drawings and build from those, so the idea that something is changing in this process isn't really accurate. I'm asking for an improved workflow that affects nothing in the real-world construction process. You don't think a ductwork subcontractor works off of design drawings in the field, do you? The drawings that I have to produce are not meant as construction drawings, but they will simply be overlays of the models that will produce the contruction drawings.
Nobody uses every single aspect of any software package. It's 2012, I think we can drop the "bloat" complaint from the discussion from now on as it's not like the computers we're all using can't handle larger programs, or that there isn't already all manner of features in any software package that one person or another isn't using. I'm not a tech guy, or a computer guy, I'm just a guy that has to comply with a contract, and wants to do it in the least amount of time and with the least amount of opportunity to make mistakes. Either that or Autodesk should go back to selling Navisworks like they did when it was Jetstream so we can all a-la-carte the features we want and only pay for what we're using.
