• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Navisworks
    Active Contributor
    Re: Converting Navisworks to dwg
    05-07-2010 02:33 AM in reply to: ben.furness
    Hi, I'm reading this thread and still not very sure on the answer to the original question.
    Can Navisworks convert to dwg or dxf?
    I'm a 3dsMax user and am looking to import files for rendering and animation, and have no idea about Navisworks' exporting capabilities.
    I have acces to the exported PDS model, along with .nwd files, and I can request export of any other formats available.
    Max can import;
    FBX, 3ds, DWG, DXF, DAE, IGES, OBJ, SKP
    Thanks for any input.
    Alan
    Please use plain text.
    Employee
    05-07-2010 03:13 AM in reply to: ben.furness
    Hi Alan,
    Navisworks 2011 will allow you to export to FBX format, which offers you an interop path with MAX.
    Best regards,
    Richard
    Active Contributor
    05-07-2010 03:35 AM in reply to: ben.furness
    Thanks Richard, that will make my life a lot easier.
    Active Contributor
    04-04-2012 12:48 PM in reply to: ben.furness
    I have 2012 Navisworks Manage which will export a DWFx, DWF and FBX but have yet to successfuly import either into Acad
    Active Contributor
    04-04-2012 12:59 PM in reply to: Dumfatnhappy
    wow,  responded to my own thread I started in 09.....   WHO KNEW..    !        :smileysurprised:
    Member
    08-01-2012 09:26 PM in reply to: WatsonAlan7507
    A workflow to get dwf back into Revit, may also help you back into AutoCAD.
    dwf open on Navisworks
    export to fbx
    Open in 3DS Max (unless AutoCAD can open fbx)
    export to sat(acis)
    acis into AutoCAD
    This is crude, yet gives you a geometric framework to generate additional geometry. Revit output dwf that aligns with the original dwf in Navisworks. I'm not sure if AutoCAD is the same.
    Good Luck
