• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Navisworks
    Active Member
    Can't view C3D surface in Navisworks 2012
    298 Views, 2 Replies
    02-04-2013 12:13 PM
    For the life of me I can't view the C3D 2013 (saved as a 2010 file) surface in my Navisworks 2012 (OE's installed).
    See the pdf attached.
    All I get is an empty box with the same dimensions as my surface.
    I've been able to view these before if I explode the TIN surface but I don't like that option.
    Any help would be very appreciated!
    Please use plain text.
    dgorsman
    Re: Can't view C3D surface in Navisworks 2012
    02-05-2013 11:33 AM in reply to: kikkertd
    Not sure if thats possible.  While you may save down to an earlier DWG format, the Civil3D vertical content is still 2013 format that will never down-convert (can't down-convert a project to work on in an earlier version of Civil3D, for example).  The only other thing I can think of is ensure the DWG Reader version is set properly in Options.
    Adopt. Adapt. Overcome. Or be overcome.
    Active Member
    02-05-2013 11:37 AM in reply to: dgorsman
    That's my conclusion today too.
    Autodesk support has been looking at this for 3 weeks and hasn't figured it out, atleast if I understand their writing correctly...
    Getting 2013 today!
    thanks
