• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Navisworks
    Active Contributor
    Can URL links associated with Revit components become hyperlinks in Navisworks?
    783 Views, 3 Replies
    12-30-2010 07:58 AM
    My testing suggests no, but I am hoping I missed something.  I am able to copy the url information and create a link, but I am hoping for automation.
    Please use plain text.
    Re: Can URL links associated with Revit components become hyperlinks in Naviswor
    01-02-2011 04:36 AM in reply to: nelsonweeks
    I have no experience with Revit, but I know that when an URL is in a DWG, it remains in the published DWF.
    and I know that NavisWorks Freedom can open DWF.
    So maybe you can publish to DWF from Revit,
    and open the DWF in NavisWorks Simulate and see if you have URLs.
    But it's just a hunch....
    Product Support
    01-04-2011 02:17 PM in reply to: nelsonweeks
    Hello nelsonweeks,
    Users have imported URL links as properties, but the links themselves will not be active links. That is, you will not be able to click on them and navigate directly. The links would be text-based.
    Thank you for participating in our community!
    David Dembkoski
    Product Support Specialist
    Autodesk Product Support
    Valued Contributor
    03-02-2012 01:56 AM in reply to: dembkod
    I also have a question about this. In the current version converting URL's is partially possible. If you create a Revit parameter of type URL, and in the export settings you choose 'convert URLs', then the URL properties that are type-parameters, come as an active link in Navisworks. But I have 2 questions about this:
    1: Why does the conversion of URL's only work on Type-parameters and not on Instance-parameters?
    2: Why are all the names of the links 'Revit' instead of the parametername?
