- Mute
- Permalink
- Report
Do you get any of the following problems within Navisworks?
- When you render your model through Presenter, only the background shows, or you seem to get holes or triangles missing from a render
- When you navigate the model it looks like you have a section plane in front of you, as describedhere
- Jerky performance when navigating
- Model disappears when rotating around the model
- When you zoom out the model disappears
- Two faces seem to occupy the same space giving a jagged looking surface
Lee Mullin
Construction Technical Specialist
Autodesk Ltd.
