• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Navisworks
    Valued Mentor
    jclaidler
    Add Service Pack 1 to Deployment
    467 Views, 7 Replies
    11-23-2009 09:41 AM
    I have an existing deployment image of Navisworks 2010, for which I want to add the Service Pack to.
    When I go to modify the deployment, I see no option to add this. Am I missing something, or does this option not exist as it does for other Autodesk applications?
    Thanks for any help.
    _______________________________________________________________
    ITO - Application Management
    Factory Design Suite Ultimate 2012
    AutoCAD 2012 | Inventor Professional 2012 | Vault Professional 2012
    Please use plain text.
    Re: Add Service Pack 1 to Deployment
    11-24-2009 03:48 AM in reply to: jclaidler
    Correct, the option does not exist. The service pack will need to be run after the deployment is installed.
    Andy
    Valued Mentor
    jclaidler
    11-24-2009 04:34 AM in reply to: jclaidler
    Thats very inconvenient. Thanks for the update, but this is needed for future releases.
    11-24-2009 05:54 AM in reply to: jclaidler
    If you want to describe the nature of inconvenience, that would be helpful. At this moment, we have no plans to add the option in for 2011.
    Andy
    Valued Mentor
    jclaidler
    11-24-2009 06:08 AM in reply to: jclaidler
    I'm a CAD Manager for roughly 3,000 users. We roll out deployments silently and they get installed overnight.
    It would be nice, like the other Autodesk applications, to be able to include the service packs into the deployment. Makes installation much easier.
    11-24-2009 07:16 AM in reply to: jclaidler
    Is it not sufficient to run the service pack silently? Pass /S (note: Captial S, /s will not work) as the argument to the service pack executable.
    For new installs, could you not create a batch script that first runs the deployment, then runs the service pack afterwards? A batch script to do this would look something like this:
    pushd *setup.exe folder*
    setup.exe /Script /Wait /Language en-US *deployment_inifile*
    popd
    service_pack.exe /S
    Andy
    *Matt Stachoni
    01-11-2010 11:10 AM in reply to: jclaidler
    The question is not "is it not sufficient to do X Y Z workaround."
    The question is why does the Navisworks team feel it's OK not to follow the same
    higher and MUCh more convenient standard set by the rest of Autodesk's
    applications?
    Matt
    matt@stachoni.com
    >popd
    >service_pack.exe /S
    >Andy
    01-12-2010 12:59 AM in reply to: jclaidler
    Matt,
    Our installer has a number of complexities not present in other Autodesk products that mean we cannot use the same service pack procedure. It is our desire to follow the standards of other Autodesk products but in some cases it is not possible.
    Andy
