Autodesk Navisworks
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Acoustical ceiling tiles line don't show up
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
After I export the both the gyp ceiling and the acoustical ceiling tiles as NWC file from Revit and append it into Navisworks, the grid pattern of the acoustical ceiling tiles doesn't show up. So the gyp ceiling and acoustical ceiling tiles look the same visually.
Is there a way to make those ceiling tiles lines show up in Navisworks?
Thanks in advance.
Re: Acoustical ceiling tiles line don't show up
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Check on the Viewpoint tab / Render Style panel / Lines button. Is the Lines button on?
Actually, I forgot myself here, I was thinking of AutoCAD ceilings. Revit has a difficult time with exporting simple geometry like lines and arcs to the NWC. What I have had to do in the past to get the visual of Revit ceilings like I want is to use the Presenter material / Pattern / grab Grid and tweek as needed.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
No, the lines still don't show up even with the line render style checked.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi diesellam
The Navisworks exporter for Revit does not support Revit Materials. It will bring across colors, but not surface patterns or material images. As the ceiling grid is a surface pattern from the material on the ceiling, this explains the behavior.
I recommend posting a wishlist item for this on our feedback page, as our development reviews the information you send through this page, and coming from an end user, it offers a compelling business case.
- http://usa.autodesk.com/adsk/servlet/index?siteID=
You can draw model lines over the ceiling grid pattern, and these model lines will export to lines in Navisworks.
There is also an article on Steve Stafford’s Revit OpEd blog that provides a workaround:
Ceiling Grid in Navisworks
http://revitoped.blogspot.com/2011/08/ceiling-grid
Best regards,
John Lipp
Support Specialist
Product Support
