• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Navisworks
    Active Member
    300 DPI image
    179 Views, 1 Replies
    08-06-2012 01:46 PM
    Hi all,
    I'm trying to render an image in navisworks that is atleast 300 dpi. My image is 8.5"x11". So far I've adjusted the output resolution to 2550x3300 and it renders fine. But when I check the properties of the JPG in widows explorer it tells me the image is only 96 dpi...
    Any help/advice?
    Thanks!
    Please use plain text.
    New Member
    ulrikdanchristensen5066
    Re: 300 DPI image
    08-29-2012 03:50 AM in reply to: mrmcclenathan
    hi,
    In order to meet a DPI resolution you need to calculate how many pixels is needed. I made a spreadsheet you may use to calculate the pixels needed -  link:  pictureresolutioncalculator
    U
