• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Navisworks
    2012 Redline thickness override?
    129 Views, 3 Replies
    08-20-2012 09:47 AM
    The default thickness setting appears to be 3.
    I prefer 5 as it is easier to see in viewpoints, but I cannot locate where the default is set at.
    I tried changing it after deleting lastsession.xml to see if that would change it (doesn't) and also
    tried saving out my workspace with this setting to no avail.
    Ideas?
    Perk
    Please use plain text.
    Product Support
    alan.quinn
    Re: 2012 Redline thickness override?
    08-22-2012 09:25 AM in reply to: steveperkio8850
    Please go here http://docs.autodesk.com/NAVMAN/10.0/ENU/Autodesk%20Navisworks%20Manage%202013%20Online%20Help/index...
    and do a search for Redline Tools Panel
    Thank for posting your question,
    Alan Quinn
    Support Specialist
    Product Support
    08-22-2012 09:34 AM in reply to: alan.quinn
    Thanks, but I already have that info unless I'm missing something that you were trying to show me.
    I have to change it in every drawing every time that I open it or them.
    I was hoping for a global default setting for this in the advanced options editor or elsewhere.
    I found this option, but it always defaults back to 3 no matter what I change it to.
    Perk
    dgorsman
    08-23-2012 09:20 AM in reply to: steveperkio8850
    Do you have a global options XML file in one of the search locations?  They always seem to work for the things that I don't want to manage, and not work for the things I *do* want to manage.
    Adopt. Adapt. Overcome. Or be overcome.
