• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Navisworks API
    Member
    Why Navisworks 2013 doesn't show one property while 2012 does?
    233 Views, 3 Replies
    08-13-2012 11:31 PM
    I am not sure if the question should be posted on API forum or not but our team believe the issue does affect us working on a program to interact with Navisworks on ifc file exported from Tekla Structures.
    In Navisworks 2012 when it opens the ifc file exported from Tekla Structures, there is a GLOBALID property field in IFC tab; however in Navisworks 2013 that field doesn't exist anymore. Our previous wriiten code relies on that field to transfer information betwwen Tekla Structures and Navisworks. I have attached a screenshot for the question. Can anyone help me on this, thanks!
    Jiancheng
    Please use plain text.
    ADN Support Specialist
    xiaodong.liang
    Re: Why Navisworks 2013 doesn't show one property while 2012 does?
    08-14-2012 03:58 AM in reply to: jianchengzou
    firstly, I did not see the screenshot you mentioned. But if you cannot see this tab in product (UI), I would suggest you submit the case in the board:
    http://forums.autodesk.com/t5/Autodesk-Navisworks/bd-p/372
    It looks you have done so.
    If you find any issue in using the API, please log the question in this board.
    Xiaodong Liang
    Developer Technical Services
    Autodesk Developer Network
    Member
    08-15-2012 02:41 AM in reply to: xiaodong.liang
    Hi Xiaodong,
    Oops. I did forget to attach the screenshot from my team colleague. If you have any idea for why the property(GLOBALID) is missing in Navisworks 2013, please keep me informed. Many thanks!
    Jiancheng
    xiaodong.liang
    08-16-2012 12:13 AM in reply to: jianchengzou
    I did not find such report in our database. But it looks a problem to me. Sorry.
    Hopefully the guru on the product board could share a comment.
    Xiaodong Liang
