• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Navisworks API
    What data read by Naviswork
    130 Views, 3 Replies
    01-18-2013 12:08 AM
    Hi All,
    I want to add custom data to an entity in AutoCAD that can be display in Naviwork Properties, is it possible?
    I'm using AutoCAD 2011 and Visual Express 2010
    Please use plain text.
    ADN Support Specialist
    xiaodong.liang
    Re: What data read by Naviswork
    01-21-2013 09:24 PM in reply to: AbuFaisal
    for native AutoCAD entity, you have to add the additional properties on the file of the Navisworks format. i.e. after the original DWG is converted to nwd, iterate the model items and add the properties to them by Navisworks API.
    for the custom entity, please refer to
    http://adndevblog.typepad.com/aec/2013/01/display-custom-properties-of-dwg-in-navisworks-1.html
    http://adndevblog.typepad.com/aec/2013/01/display-custom-properties-of-dwg-in-navisworks-2.html
    currently, no way (or no options) to import xdata to Navisworks
    Xiaodong Liang
    Developer Technical Services
    Autodesk Developer Network
    01-24-2013 06:18 PM in reply to: xiaodong.liang
    Hi xiaodong.liang
    I'm installing visual express now, so I can't install Object ARX. However I look to your website to following address : http://adndevblog.typepad.com/aec/2012/05/create-attributes-and-properties-for-model-objects-using-n...
    which looks like can do what I want.
    The problem is I'm a real dummy in naviswork, can you tell me how to load dll file we created, and is it also possible to run our code without running the naviswork software? I have checked to the documentation but still confusing for me
    xiaodong.liang
    01-28-2013 07:22 PM in reply to: AbuFaisal
    do you mean Navisworks plugin dll file?  Please read the tutorial
    C:\Program Files\Autodesk\Navisworks Manage 2013\api\net\documentation\NET API.chm >> Developer Guide >> Writing Plug-ins.
    If you meant by ObjectARX dll, I'd suggest you get started with by the materials below:
    ObjectARX 2013 Training
    ObjectARX 2010/2012 Training
    Xiaodong Liang
