• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Navisworks API
    New Member
    Viewing NWD files in IE9
    291 Views, 1 Replies
    08-23-2012 01:46 PM
    I am trying to get NWD files to be viewable in IE9, and so far I have no luck.  Below is what I'm using and what I've done.
    OS: Windows 7 64bit
    Browser: IE9 32bit
    Plugin: Autodesk Navisworks ActiveX Redistributable 2013
    File: gatehouse.nwd
    NWD file Path: Same path as the html file
    Mime Type is set on the server
    Using sample code from http://adndevblog.typepad.com/aec/2012/08/enable-event-of-activex-control.html#comment-6a0167607c243...
    I don't know what the issue is, it just doesn't seem to work.  I either just get a black box or nothing at all as if no plugin is installed.  Is there a step by step procedure I can follow?  Please help.
    Please use plain text.
    ADN Support Specialist
    xiaodong.liang
    Re: Viewing NWD files in IE9
    08-28-2012 02:00 AM in reply to: jyan21
    As answered in the blog,  Redistributable control of 32bit and 64bit can both be installed on 64bit OS side by side. The Navisworks ActiveX Redistributable Setup.exe in 64bit Navisworks provides the 64bit Redistributable control. So to open it , it requires IE-64bit.
    Xiaodong Liang
    Developer Technical Services
    Autodesk Developer Network
