• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Navisworks API
    jordanmarr
    Search with "OR"
    283 Views, 2 Replies
    11-21-2011 07:04 AM
    I have a Search with multiple SearchCondition objects added.  By default, conditions added create an "AND" style search.
    Is there a way to do an "OR" style search?
    More specifically, I have a list of element ids, and I want to know if it is possible to search for them all at once.
    If not, then I suppose I could create a speparate search for each element.
    Please use plain text.
    ADN Support Specialist
    xiaodong.liang
    Re: Search with "OR"
    11-23-2011 10:48 PM in reply to: jordanmarr
    I assume you are using .NET API. This needs SearchCondition group. It is "AND” within one group. It is "OR"  among groups.  The code below is tested with the SDK sample model:  gatehouse.nwd.
    //Create a new search
    Search s = new Search();
    s.Selection.SelectAll();
    //SearchCondition1 of group1:the item is required
    SearchCondition oGroup1_SC1 = SearchCondition.HasPropertyByDisplayName("Item", "Required");
    oGroup1_SC1 = oGroup1_SC1.EqualValue( VariantData.FromBoolean(true));
    //SearchCondition2 of group1:the item's DWG handle is 16C17
    SearchCondition oGroup1_SC2 = SearchCondition.HasPropertyByDisplayName("Entity Handle", "Value");
    oGroup1_SC2= oGroup1_SC2.EqualValue( VariantData.FromDisplayString("16C17"));
    //SearchCondition1 of group2: the item is NOT required
    SearchCondition oGroup2_SC1= SearchCondition.HasPropertyByDisplayName("Item", "Required");
    oGroup2_SC1 = oGroup2_SC1.EqualValue(VariantData.FromBoolean(false));
    //SearchCondition2 of group2: the item's DWG handle is 17C2E
    SearchCondition oGroup2_SC2 = SearchCondition.HasPropertyByDisplayName("Entity Handle", "Value");
    oGroup2_SC2 = oGroup2_SC2.EqualValue(VariantData.FromDisplayString("17C2E"));
    //create group1
    System.Collections.Generic.List<SearchCondition> oG1 = new System.Collections.Generic.List<SearchCondition>();
    oG1.Add(oGroup1_SC1);
    oG1.Add(oGroup1_SC2);
    //create group2
    System.Collections.Generic.List<SearchCondition> oG2 = new System.Collections.Generic.List<SearchCondition>();
    oG2.Add(oGroup2_SC1);
    oG2.Add(oGroup2_SC2);
    // add groups to SearchConditions
    s.SearchConditions.AddGroup(oG1);
    s.SearchConditions.AddGroup(oG2);
    //highlight the items
    ModelItemCollection searchResults = s.FindAll(Autodesk.Navisworks.Api.Application.ActiveDocument
    Xiaodong Liang
    Developer Technical Services
    Xiaodong Liang
    Autodesk Developer Network
    jordanmarr
    11-30-2011 01:05 PM in reply to: xiaodong.liang
    Great!  Thank you very much.
    Jordan
