• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Navisworks API
    Active Member
    derek.jarvis
    Retreive File Date of Model Components
    59 Views, 1 Replies
    07-26-2012 05:34 PM
    Is it possible to retrieve file information about the model items in an NWD file?
    I am able to retrieve the initial publish date of the root NWD with the API, but I would like to know the file date for all the sub items within the NWD.
    The reason I would like this is so I can determine which models changed within the main Navisworks file based on date stamp between two versions
    Please use plain text.
    ADN Support Specialist
    xiaodong.liang
    Re: Retreive File Date of Model Components
    08-14-2012 04:04 AM in reply to: derek.jarvis
    I am not clear what the information is. Probably you could upload a screenshot?
    Basically, if the property can be seen in the Properties dialog in UI, it can be accessed by API. If no, API cannot get the info, either.
    Xiaodong Liang
    Developer Technical Services
    Autodesk Developer Network
