Hi
this is with ActiveX control for Navisworks in web
my project is ready in local host but in intranet dont view model. Help please
MY PROJECT, LOCALLY CAN NOT DISPLAY PROBLEM, BUT WHEN IT COMES TO THEWEB SERVER IIS ROUTE, AND LETS NOT VIEW THE MODEL.
it would have to configure any port on the ISS or something with the firewall
Before 2012, we provided
1.1 Lite control
1.2 Full control
1.3 Dynamic control
From 2012, we provided:
2.1 Redistributable control
2.2 Integrated control
No matter any controls, it requires the client machine has installed them.
For 1.3 and 2.2, this requires the client machine has installed Navisworks (Simulate/Manage). These two controls are built-in control. They are installed when the products are installed.
For 1.1, you need to put the nw_ax_lite.cab on your server and make sure your HTML can ask user to run the CAB to install Lite control.
For 1.2, you need to put the NavisworksFullActiveXSetup.exe on your server and make sure your HTML can ask user to run the exe to install Full control.
For 2.1 you need to put the Navisworks ActiveX Redistributable Setup.exe on your server and make sure your HTML can ask user to run the exe to install Redistributable control.
These CAB or EXE can be found in <Simulate/Manage>\api\COM\bin
No matter any controls, you need to make sure you specify the correct GUID of the corresponding control.
The GUID can be found in registry with the key words, e.g. “Navisworks Lite”
One more thing, you need to specify the MIME type for Navisworks document. Please refer to the attached screenshot.
Xiaodong Liang
Developer Technical Services
I've modified the example ACTX_01 and replaced the model with one of my own. It's a 2011 nwd file, and the example web page is from the 2012 installation.
Just opening the web page as it is will cause the plugin to look for a license, but following the instructions from here, I changed the GUID in the HTML code and the nwd will display in the web page without a license. However, all the links disappeared from the model. How can I fix this?
Also, when searching the registry, several GUIDs can be found, what's the difference between them all?
Btw, where exactly do I specify the MIME-type as described above?
Thanks..
1) URL (hyperlink), please try with state.URLsEnabled = true.
2) guids:
each type of control has unique id. e.g.
lite control
full control
dynamic controk
integrated control SDI
integrated control MDI
redistributable control SDI
redistributable control MDI
in different releases, the guids of same type of control are different.
3) MEMI type, I attached a screeshot in the last post. Please check it.
1) Where do I put that line? In the original HTML-code, in the VB-script section, it says:
public sub btnLinkOn_Clicked()
NWControl01.state.URLsEnabled = TRUE
end sub
public sub btnLinkOff_Clicked()
NWControl01.state.URLsEnabled = FALSE
end sub
Changing the last section to "TRUE" doesn't do anything. Besides, when using the original/license GUID, the links show up, but when changing to the redistributable GUID they disappear.
2)
What's the difference between "Navisworks Redistributable Control 9 MDI" and "... SDI"?
Thanks.
1) URLsEnabled should work for Redistributable control. However we do have such problem logged for Full control (before 2012, this control is similar to Redistributable control). Sorry for this.
2) SDI means in one application, you can use only one control. while MDI means you can use multi. In the past, the ActiveX control based application supports only one control.
