• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Navisworks API
    Distinguished Contributor
    Limit selection to specific objects
    132 Views, 3 Replies
    01-22-2013 11:59 AM
    I would like to limit the selection to spicific objects. A portion of the model is transparent and I would like to be able to select objects through the transparent objects. Is that posible? Thanks.
    Please use plain text.
    ADN Support Specialist
    xiaodong.liang
    Re: Limit selection to specific objects
    01-23-2013 05:58 PM in reply to: bthatcher
    I'd suggest you take a look at Find API of Navisworks. here is one post which you could get started with.
    http://adndevblog.typepad.com/aec/2012/05/navisworks-net-api-find-item.html
    e.g. for your question, one way could be:
       Document oDoc =
                   Autodesk.Navisworks.Api.Application.ActiveDocument;
               IEnumerable<ModelItem> items =
                       from x in oDoc.Models[1].RootItem.
                           DescendantsAndSelf
                       where x.HasGeometry && x.Geometry.ActiveTransparency >0
                       select x;
               // highlight the items
               oDoc.CurrentSelection.CopyFrom(items);
    Xiaodong Liang
    Developer Technical Services
    Autodesk Developer Network
    01-31-2013 11:53 AM in reply to: xiaodong.liang
    I'm not sure I've explained myself clearly. I have a model with several modelItemCollections. Some of the modelItems are have a 95% transparency, the rest no transparency. I want to select on the screen but only be able to pick the non-transparent modelItems. They are part of thier own modelItemCollection. So in the attached image, if the user clicked where the red arrow is, they woukd get the cyan modelItem, even though that modelItem is behind the transparent modelItem denoted with the red boundry. Thanks.
    xiaodong.liang
    02-19-2013 02:36 AM in reply to: bthatcher
    I see. you want to cusmomize the selection when user is selecting. Sorry, in current releases, the picking behavior cannot be customized. Even though you could get OnCurrentSelectionChanged(/Chaning), API does not allow you to change the selection in the events.
    Xiaodong Liang
