• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Navisworks API
    New Member
    Is there a way to display the Naviswork viewer control in a web browser(ASP.NET)
    377 Views, 4 Replies
    07-13-2012 02:35 AM
    We have the navisworks viewer control working in windows application.
    Is there a way to display the navisworks viewer in a web browser(ASP.NET), I mean in a .aspx page
    if possible please post me a sample piece of code.
    Prasanth.k
    Please use plain text.
    Member
    Re: Is there a way to display the Naviswork viewer control in a web browser(ASP.
    07-24-2012 02:21 AM in reply to: prashanthmallu
    Hi prashanthmallu,
    I've managed to get the control working in an ASP.Net page, but I'm having some problem getting the controls for selecting other .nwd files etc working...
    I just asked a question about it and posted a link to some blog posts by Xiaodong Liang http://forums.autodesk.com/t5/Autodesk-Navisworks-API/Navisworks-ActiveX-Control/td-p/3549588
    Hope that helps you.
    Cheers....
    John
    New Member
    07-24-2012 11:50 PM in reply to: prashanthmallu
    using the below code, i too was able to view the .nwd file on a .aspx page.(using Navisworks Redistributable Control 10 SDI)
    Now i am trying to do a search in the model?But it seems we need a licensed version to execute this code.
    i am getting an error "Microsoft JScript runtime error: <<NavisWorks Error - API Unlicensed>>"
    So i am planning to test it in a licensed version.
    Please share me the code that you have too.
    <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
    <html xmlns="http://www.w3.org/1999/xhtml">
    <head>
    <title>NavisWork Sample</title>
    <script type="text/javascript">
    function test(){
    alert('called');
    var state = ctrlId.state;
    var find = state.ObjectFactory(state.GetEnum("eObjectType_nwOpFind"));
    var findspec = state.ObjectFactory(state.GetEnum("eObjectType_nwOpFindSpec"));
    var findcon = state.ObjectFactory(state.GetEnum("eObjectType_nwOpFindCondition"));
    findcon.SetPropertyNames("LcOaNat64AttributeValue");
    findcon.SetAttributeNames("LcOpDwgEntityAttrib");
    findcon.Condition = state.GetEnum("eFind_EQUAL");
    findcon.value = "M/4";
    findspec.Selection.SelectAll();
    findspec.Conditions().add(findcon);
    find.FindSpec = findspec;
    var sel = find.FindAll();
    state.CurrentSelection = sel;
    state.ZoomInCurViewOnCurSel();
    </script>
    </head>
    <body>
    <input type="button" value="Click Here" onClick="test();">
    <div id="canvas" style="position: absolute;top:50px; left: 0px; text-align: center; background-color: #ccc">
    <object id="ADViewer" classid="clsid:99D47D37-9B2A-4EBF-8CD9-F16FFB9BF4C5" border="1"
    width="1300" height="700" viewastext>
    <param name="Src" value="G:\VCP\VC Test 2.nwc">
    </object>
    </div>
    <div id="SectionList" style="position: absolute; top: 100px; left: 425px; width: 175px;
    height: 400px; text-align: left; font-size: 10pt; background-color: #ccc">
    List of Sections:</br></br>
    </div>
    </body>
    </html>
    Member
    07-25-2012 12:36 AM in reply to: prashanthmallu
    My code is pretty much the same as yours.
    I think that there are only limited functions you can do with the Redistributable API and a license is required for using the Integrated API.  That's certainly how it appears to me, but like I said before, last week I had no idea what Navisworks was so I can't be certain.
    Have you saw this thread discussing the licensed API? http://forums.autodesk.com/t5/Autodesk-Navisworks-API/Use-Naviswork-ActiveX-with-Licensed-API/td-p/3...
    ADN Support Specialist
    xiaodong.liang
    08-02-2012 12:40 AM in reply to: johncondron
     johncondron  is correct.  As the blog says: the functionalities of Redistributable control are very limited. You will need to use Integrated control to have the full abilities.
    Xiaodong Liang
    Developer Technical Services
    Autodesk Developer Network
