How to get category Index to update category to model item
Hi, Everyone,
     In my in-house NW Plug-in, I need add user defined properties to a specify category,
             After first time, I need get category index to update it (code as below), If somebody can
             help , I am very appreciated.
Lee, Wenhan
Code as below :
            Navisworks.ModelItemCollection mic = new Navisworks.ModelItemCollection();
            mic.Add(model);
            ComApi.InwOpSelection comSels = ComApiBridge.ComApiBridge.ToInwOpSelection(mic);
            ComApi.InwSelectionPathsColl oPaths = comSels.Paths();
            ComApi.InwOaPath3 oPath = oPaths.Last() as ComApi.InwOaPath3;
            ComApi.InwGUIPropertyNode2 pNode = (ComApi.InwGUIPropertyNode2)state.
                    GetGUIPropertyNode(oPath, true);
            ComApi.InwOaPropertyVec newPvec = state.ObjectFactory
                    (ComApi.nwEObjectType.eObjectType_nwOaPropertyVec, null, null) as ComApi.InwOaPropertyVec;
            ComApi.InwOaProperty newP;
            foreach (DataRow dr in prps)
                        newP = state.ObjectFactory(ComApi.nwEObjectType.eObjectType_nwOaProperty, null, null)
                                as ComApi.InwOaProperty;
                        newP.name = dr["PName"] as string;
                        newP.UserName = dr["PName"] as string;
                        newP.value = dr["PValue"] as string;
                        newPvec.Properties().Add(newP);
                        //MessageBox.Show(dr["PName"] + " " + dr["PValue"], strModel);
            int idx = getIndexCategory(model, catName);
            pNode.SetUserDefined(idx, catName, catName, newPvec); // idx 0: Append, othesr is replace
        int idx = getIndexCategory(pNode, catName);
        private int getIndexCategory(ComApi.InwGUIPropertyNode2 pNode, string catName)
            int idx = 0, rst = 0;
            foreach (ComApi.InwGUIAttribute2 attribute in pNode.GUIAttributes())
                if (attribute.UserDefined)
                    idx++;
                    if (attribute.ClassUserName == catName)
                        rst = idx;
                        break;
            return rst;
xiaodong_liang
Autodesk Support
Autodesk Support
Hi ctci20299 ,
yes, what you are doing is the only way. The API does not provide the index for the catergory or property. You will need to iterate the collection and calculate the index. I would suggest storing the information.thus you can re-use them next time.
