• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Navisworks API
    karteek.iitm
    Hide model items
    190 Views, 11 Replies
    01-10-2013 10:45 PM
    I am trying to read selection items for tasks in timeliner and trying to hide them using API.
    this is the code for the same.
    foreach (Tl.TimelinerTask oTask in tl_doc.Tasks)
          DateTime date2 = oTask.ActualStartDate.Value.Date;
          int result = DateTime.Compare(date1, date2);
          if (result > 0 || result == 0)
              Tl.TimelinerSelection oTlSel = oTask.Selection;
             if (oTlSel != null)
                             if (oTlSel.HasExplicitSelection)
                                         Nw.ModelItemCollection oExplicitSel = oTlSel.ExplicitSelection;
                                       Autodesk.Navisworks.Api.Application.ActiveDocument.Models.SetHidden(oExplicitSel, false);
    But when i debug the program it says "the name 'oExplicitSele' does not exist in the current context. Can anyone please explain how to hide selection items attached to a task.
    Please use plain text.
    ADN Support Specialist
    xiaodong.liang
    Re: Hide model items
    01-10-2013 11:04 PM in reply to: karteek.iitm
    It is C# and you are using oExplicitSel in the brackets,  right? I beleive you have figured it out after posting the question :smileyhappy:
    Xiaodong Liang
    Developer Technical Services
    Autodesk Developer Network
    karteek.iitm
    01-11-2013 12:41 AM in reply to: xiaodong.liang
    Thank you for your reply Mr. Xiaodong Liang.
    When i run the code I am facing the following error (although i added the dll as a refrence in thr app). Can you please explain why this is happening.
    System.IO.FileNotFoundException: Could not load file or assembly 'Autodesk.Navisworks.Timeliner.dll' or one of its dependencies. The specified module could not be found.
    karteek.iitm
    01-11-2013 12:42 AM in reply to: karteek.iitm
    I have also added all the dependencies through .net reflector.
    xiaodong.liang
    01-13-2013 11:01 PM in reply to: karteek.iitm
    Please take a look at this post. Hope you could find what you missed.
    http://adndevblog.typepad.com/aec/2012/10/timeliner-api-part1.html
    In addition, please switch the .NET framework to 4.0 if it helps.
    Xiaodong Liang
    karteek.iitm
    01-18-2013 03:44 AM in reply to: xiaodong.liang
    I developed my code based on the link which you have provided and did not miss anything.
    .NET Framework 4.0 does not help too.
    xiaodong.liang
    01-21-2013 09:33 PM in reply to: karteek.iitm
    So, I believe your app is a standalone EXE of .NET control. Unfortunately TimeLiner/ClashTest has not exposed to .NET control. you can only use them in a plugin.
    The possible way I can think of is: you create an automation and plugin. plugin accesses timeliner and writes the info you need into a temporary file. When your app of .Net control wants to get timeliner info, it launches the automation, the automation starts a process of Navisworks (invisible), executes the plugin. finally, the app pf .Net control reads the temporary file and gets the info.
    Xiaodong Liang
    karteek.iitm
    01-22-2013 04:51 AM in reply to: xiaodong.liang
    That helps a lot. Thank you for the information.
    Active Member
    02-24-2013 11:22 AM in reply to: karteek.iitm
    you havent included the .dll file in references. please find it in navisworks freedom folder. cheers.
    xiaodong.liang
    02-26-2013 05:01 PM in reply to: dickinsjohn
    Hi dickinsjohn,
    I am not sure which question you are answering. But please note: no API for Freedom.
    Xiaodong Liang
