• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Navisworks API
    New Member
    talesfc
    Accepted Solution
    Help with DockPanePlugin
    139 Views, 3 Replies
    10-04-2012 12:20 PM
    Hi
    I am new to Navisworks API and would like help on using the DockPanePlugin. I have read the "DockPane Tutorial" by Le Zhang (http://lezhang.net/2012/06/13/navisworks-2013-api-dockpane-tutorial/) and tested the  DockPane Helloword example.
    However I have not found pointers on how to access gui controls on the panel. For example, how can I set/get the text content on a textblock on the panel ?
    regards
    Tales
    Please use plain text.
    Employee
    saikat
    Re: Help with DockPanePlugin
    10-04-2012 05:35 PM in reply to: talesfc
    Hi Tales
    Once you have GUI controls on the panel, you can access it in the same way you would have accessed a GUI located on a Windows Form from the class which initializes the Form. So the options are -
    Making the GUI control's (say TextBox) modifier public and acessing it from the, say, BasicDockPanePlugin.cs class in the BasicDocPanePlugin SDK sample.
    Or Passing the variable parameter to the Panel and using that to get/set the values of a TextBox - just like it has been done for the Label in the same SDK sample.
    Hope this helps.
    Saikat Bhattacharya
    New Member
    talesfc
    10-06-2012 05:37 PM in reply to: saikat
    Hi Saikat,
    Thanks for helping. Following your advice I succeeded accessing the wpf control.
    regards
    Employee
    saikat
    10-07-2012 11:19 PM in reply to: talesfc
    Thats great to hear, Tales. Thanks for letting me know.
    regards
    Saikat Bhattacharya
