• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Navisworks API
    New Member
    Accepted Solution
    Adding a custom Task to Timeliner (or adding model selections to tasks)
    268 Views, 2 Replies
    10-18-2012 04:30 AM
    Hi everybody!
    I have to write a plugin, which adds some selection to every timeliner task. By selection i mean Autodesk.Navisworks.Api.Timeliner.TimelinerSelection class.
    So, after user imports an MS Project file as a timeliner datasource, i get the timeliner object, i'm able to iterate through tasks and their children, BUT....
    but i cannot write anything to a task or timeliner object - they are all read-only. I read about it in Developers Guide(collections returned by Navisworks are read-only, collections created programmatically are writeabe), i see ReadOnly == true in objects' properties, but i hope there is a solution for this.
    So, does anybody know how to WRITE data to timeliner Tasks using .NET API?
    This is how i get access to timeliner object:
    public class navisTest :AddInPlugin
        {        static Document navDoc = Autodesk.Navisworks.Api.Application.ActiveDocument;
            static Autodesk.Navisworks.Api.DocumentParts.IDocumentTimeliner Itimeliner = navDoc.Timeliner;
            static DocumentTimeliner timeliner = (DocumentTimeliner)Itimeliner;
            TimelinerTask tsk = new TimelinerTask();
            foreach (TimelinerTask task in timeliner.Tasks)
                foreach (TimelinerTask childTask in task.Children)
                    if (!childTask.Selection.IsClear)
                        childTask.Selection.CopyFrom(newCollection);  //some  ModelItemCollection
                        //or CopyFrom(navDoc.CurrentSelection.SelectedItems.DescendantsAndSelf);
                        //anyway it crashes here - "object is readonly"
    Also, i tried to create my own Task object and add it to timeliner - the same thing, it crashes:
    tsk.Selection.CopyFrom(navDoc.CurrentSelection.SelectedItems.DescendantsAndSelf);
    timeliner.Tasks.Add(tsk);  //crashes here.
    Thanks in advance,
    Alexander.  :cathappy:
    Please use plain text.
    ADN Support Specialist
    xiaodong.liang
    Re: Adding a custom Task to Timeliner (or adding model selections to tasks)
    10-22-2012 09:08 PM in reply to: tkachenko_truboprovod
    The task cannot be manipulated directly. Please refer to the following code:
              GroupItem root_copy = timeliner.TasksRoot.CreateCopy() as GroupItem;
              try
                  root_copy.Children.Add(tsk);  //crashes here.
                    // replace the timeliner tasks
                  timeliner.TasksCopyFrom(root_copy.Children);
              catch (Exception ex)
    Xiaodong Liang
    Developer Technical Services
    Autodesk Developer Network
    New Member
    10-23-2012 12:33 AM in reply to: tkachenko_truboprovod
    Thanks a lot!
    I've already found this solution yesterdeay, and you verified my guess!
    Alexander.
