• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Navisworks API
    New Member
    Active X Clicked Events: Predefined vs Dynamic
    172 Views, 3 Replies
    08-30-2012 04:15 PM
    I am curious to know if there is a way to generate a link between an object in the model to some database information without having the link being predefined?  For example, as I am viewing my model on a website and click on a beam in the model I can have a defined link to show some information regarding that beam.  Is it possible to create that link through some UI on the webpage itself?
    Chris
    Please use plain text.
    ADN Support Specialist
    xiaodong.liang
    Re: Active X Clicked Events: Predefined vs Dynamic
    09-03-2012 11:28 PM in reply to: clam2020
    The way I can think of is to monitor the mouse clicking event of the control, get the current selection, read the properties (if it stores the hyperlink info), or read the info from a database (if you have mapped the element with the info in the database), finally show the info.
    But I still prefer to the predefined hyperlink attached to the elements. Thus the user can click the URL directly.
    Xiaodong Liang
    Developer Technical Services
    Autodesk Developer Network
    12-04-2012 05:12 AM in reply to: xiaodong.liang
    Hi
    Would it be possible to show some example VBscript of how to get the properties from an object that has been clicked.
    I too would be very interested in acccessing this information via a web browser.
    Many Thanks
    PM
    xiaodong.liang
    01-07-2013 09:46 PM in reply to: tagbagz
    here is a blog on how to use event of Navisworks ActiveX control within a web page.
    http://adndevblog.typepad.com/aec/2012/08/enable-event-of-activex-control.html
    As to getting object's property, I'd suggest you refer to the SDK sample in <Navisworks Manage 2012>\api\COM\examples\AUTO_06. It is a sample of automation, but the core code could be borrowed to the web page application, using VBS.
    Xiaodong Liang
